[WANTED] Wiper/Washer knob
Red63440
Olddawg
Batavia, NY
Ok.....I thought we had this taken care of but a closer inspection showed that the knob I thought I had finally found is actually the wrong size for the switch I have (2864415). I have been told that the switch I have has the small shaft. I am including a sketch which gives the dimension of the shaft on my switch. If you happen to have a really nice washer knob that says "WASH" on it please make sure the spring is included.
Merry Christmas!!
If you can't find one otherwise, these are pretty easy to make from a flat piece of spring steel. I got a couple of small pieces from a specialty steel place a while ago just for stuff like this, it's a quick process to fab one up.
I found one. Not in the greatest of shape but usable if you dont have anything at all. There is a corrosion spot on the front of it.
