1967 barracuda 383 stick car. American autowire classic update series. Looking for advice on wire size on this wire that goes from starter relay batt post to starter stud. You can see the pos wire from batt (1/0), the 6 ga from megafuse. This l the wire in question looks smaller but isn't called out (as far as i can tell) ..... I'm also wondering if this wire has got to go to the starter post as i have 12 V power much closer (megafuse is right next door) starter has power straight from battery.
THANKS FABO
THANKS FABO
