Wiring A 318 Magnum
66VALIANT
ROCKDALE IL
DOES ANYONE KNOW HOW TO WIRE A 318 MAGNUM INTO A EARLY A I WANT FUEL INJECTION AND ALL DONT NEED AC OR POWER STEERING AND IT WILL BE A 4 SPEED PLEASE HELP I WORK IN A JUNKYARD AND COULD PROBABLY GET ALL THE STUFF JUST WANT TO KNOW HOW TO DO IT. IVE SEEN A FEW cARS WITH IT B 4 THANKS GUYS :notworth:
I believe there is a book for swapping in a mag motor with fuel injection. I think it's published by Mopar Performance, or HP Books.
I know that Street and Perfromance sells a harness that will cut down on all of the crap you don't need and makes the swap alot easier. Their # is
479 394-5711. Give them a call they can help you out. Trying to use a stock harness is a pain in the a$$.
Thanks some one told be a 1993 motor needs to use a dakota flywheel because og the crank sensor for tyhe ignition is this true how do i get around that
