1969dodgedart
Big Block 440
Looking for solutions on this issue , I'm mounting a temp sensor for electric fans and aftermarket gauge cluster as well as the factory gauge . Any ideas and pictures? For a 1969 dart. Thx
You know what I don't need your help specifically, was looking for constructive ideas not armchair comments.The problem I see is that sensor is on the top side of the T stat so it has to be open to be accurate. And if the Tstat fails and sticks shut.....it won't be
Can't help you much as you refuse to give any details. But as big as the castings are on B/RB pumps you can easily tap them with a little careful looking
