cudaspaz
Hey I got my line lock installed but I have a question on wiring up the hydraulic brake light switch.
I installed a 2 prong electric/hydraulic brake light switch in the outgoing port of my line lock as the instructions indicated.
My question is: Where do those two pins from the switch go in relation to the two wires on either side of my brake pedal switch?
This is so I can get my brake lights to work while the line lock is engaged.
The brake (pedal) switch has one wire at the top side of the plunger and one wire at the pedal side that swings with the pedal and makes contact with the plunger when you take your foot off the brake.
The hydraulic brake switch is not marked which pin is which so I guess it does not matter right?
