Summit Racing Scratch & Dent sale. Wiseco pistons, .030 over for $300. Anyone used them. How much lift can they take. Need an answer fast!
At the back right near the vending machines.Where the heck is the scratch and dent at summit?
The overlap period is when the piston is closest.Lift has little to do with piston to valve clearance. It's not the how much lift, it's the when the valve opens. Duration is what you need to watch. Wisecos come with generous valve reliefs, so it'll very likely never be an issue.
Brought the Wiseco's home!The icons are a good deal, but not the exceptional deal those wiseco's are.
So, 318 stroker pistons. Gonna need a real good 318 block to go 402.......(+.094). Stroker Poly, anyone?Part # UEM-IC744.STD They were flat tops. I wanted them too but I had to say no.
I thought about that. Compression would be thru the roof! What are the chances of finding a standard bore Magnum block?Oh yes, I would have bought those if I was there. Stuff those in a clean Magnum block with a fresh hone job. Pair them with Scat or K1 forged crank and rods.
Edited to add Molnar.
