swing69
I’m just an old guy……
I'm going to go with coil-overs, eliminating the T-bars in our project 64 Dart. Its getting a warmed over 360/built 904/8/75 rear. I want to make the car handle like its on rails, Frame connectors are going to be installed. I also want to go with the heavier Addco 1.125 bar, rather than the stock 7/8" front one. (I've got no info on the Firmfeel bar.....)
The following stock parts are cleaned and painted, ready to go. The front swaybar has newstyle bushings, so the stock k-frame brackets are visually a little different; LCAs with factory tabs. new rubber bushings installed, sway bar + frame brackets. All parts are cleaned, blasted and painted black.
Whats the stock set up worth? I'd like to try and offset the cost of the front Addco #751 ($160) and the rear Addco #675 ($136) OR Addco #919 (7/8).
