WIW apart dart LONG......
hosehead
Springfield Mo
So, my move back to Oklahoma next spring is quickly becoming a reality and I am figuring out what to move back with me. I have one car that I'm on the fence on what I should do with.
I am painfully aware that selling a car apart is a money losing proposition but I really don't think it will get painted before I am ready to move. So, here I am asking my fabo brethren to tell me how stupid of an idea this is....lol.
I will tell you guys what I have and you can let me know what you think I could expect to get for it in today's market. Here goes.....
My 1970 340 dart swinger is mostly apart for paint. Front end is on a dolly, rear is still in the car. Interior is also removed. But for the sake of this discussion, let's say it's a together roller with front and rear in the car and interior re-installed. I could easily reassemble it to a roller in a week or so.
Original F8 green with green interior. 340 3-speed car. Stripe delete, drip rail delete.
Notable options: 3-speed wipers with electric washer reservoir, wheel lip molding, rocker molding, passenger side mirror and pedal dress up.
I have two build sheets, clear title and lots of old receipts. Fender tag is present and in nice shape. Body numbers match
Body: body is nice. Has one 1"-2" inch hole in pass floorboard from a leaky heater core. I have a repop replacement floorpan.
Rear wheel lips have been slightly trimmed for wheel clearance.
Front and rear window channels each have two 1/8" holes in them.
Has one lower quarter extension already patched. Nicely done.
This is the extent of the body damage. Rest of the car is straight and dry.
Engine: numbers matching 340 rebuilt with forged Ross Pistons .030 over
Comp hydraulic cam, eddy performer rpm, lightly ported O heads.
Correct carter four speed carb
Original air cleaner and valve covers are present. No exhaust manifolds but I have a full tti exhaust. Ceramic coated headers with thermal barrier and 2 1/2" x-pipe system to the rear bumper.
Done by a reputable builder. 6k in receipts.
Trans: car was originally a 3-speed but I have a 4-speed trans with a Lakewood bellhousing and block plate. New TTI z-bar and all original four speed parts are present.
Rear: original 8 3/4 with correct bell drums. 3.23 open diff.
Front suspension: original k-member with washer has been powder coated along with drag link. Rest of suspension is present, control arms, sway bar etc.
original four piston disc brakes.
I have all new moog components, new in the boxes.
Wheels: 14" sbp rallyes.
Interior: original front and rear bench seats are present but have been recovered in 80's velour. Dash pad and door panels were junk so they are gone.
Rally dash bezel has been cut for a radio but is original with all instruments and original rallye dash frame.
Nos steering wheel
Nice dash vents, arm rest bases, etc
Nice headliner already in car.
Repop interior door handles
Car has straight bumpers with new repop rear lenses.
Unbroken grille, all mounting tabs present. No cracks and nos turn signals.
All new M&H wiring harnesses(dash, engine, tail light)
All new repop emblems, exterior door handles, window cranks, etc.
New fuel tank, brake parts, hoses, belts, etc.
The car is basically complete besides the windshield(was cracked when I bought it), the interior parts that need repop replacements(door panels, dash pad, etc) and the exhaust manifolds and bell housing as I have the Lakewood bell and the tti exhaust system.
I'm sure I'm forgetting plenty but you get the idea. Here is a pic.
Flame away! Thanks in advance for the opinions, guys.
from that pic. and description as a complete but rolling disassembled. 6500.00 assuming its an h code
Yes, real h-code. And that's what I have in the engine.....:lol:
Disassembled cars are a hard sell for sure.
there was one in similar condition for two months on craigsist in florida i was chomping at the bit to buy in sort of similar condition for 5999.00 it was go mango automatic a/c car needed floor pans and lower quarters. it needed disassembled and restored but it was complete, it was a numbers matching car.
E55 D21 H51 is my dream car
there was one in similar condition for two months on craigsist in florida i was chomping at the bit to buy in sort of similar condition for 5999.00 it was go mango automatic a/c car needed floor pans and lower quarters, it was a numbers matching car.
At least it's not rusty. I have that going for me...
Me? I'd put that sucker back together and haul it back to OK. Unless you have several other cars you like better, that makes the most sense. You will never replace it for what you will get out of it.
Yeah, that's what may have to happen. I just don't know if I have it in me to put it together, drag it across country and take it back apart again.
I totally get that! At 61, my get up and go has got up and went! You got to eat an elephant one bite at a time, so just plug along on it. K frame, motor and trans back in first. Make it roll only...no need to hook up stuff. Then just make sure the body parts that are off, will stay on. Pile everything else inside and you're done. When you get it to OK......you'll get to it when you get to it. If it helps any.... you only gotta drag it half way across the country. :D
Bring it to Oklahoma and sell it to me cheap.
But seriously, bolt it together as a roller, bolt the drivetrain into it. Pile the rest of the parts into it and have it shipped here. It cost $720 to ship a non-op Porsche from OK to NE Ohio. It could be torn back apart in a few hours and be ready for paint. Mopars seem to be pretty scarce here.
Back to civilization. :lol:
this, I was out there for 4 yrs. , couldn`t wait to get back !!
Altho the desert is unbeatable if u like to ride 4 wheelers.
Where bouts u coming to ??----------(okie speak!)
How much enjoyment/value will you ever get out of it versus the hassle of moving a project? That answer will tell you a lot.
I think you should try to sell it, but you don’t need to give it away either. Maybe the right buyer will find you. I expect prices to remain about where they are mostly due to the increasing age of the people that remember these cars fondly, so I don’t think in a year or two you’ll feel you missed out on the big increase in value if ‘60s & ‘70s cars.
cool , I`m just outside Collinsville/ no. of tulsa. About 9-10 miles from the dragstrip. What do udo for a living ? Coming back for the job ?
I`m retired and starting to feel like it !
Cool! Maybe I'll see you at the track sometime. I'm basically just escaping California. I worked in the film biz here for about 20 years so I'll have to find something to do work wise. I'll starting sending some resumes around Grove soon, I guess.
film industry , wild ! Good luck w/ the move, might meet some time .
