Wont crank
T.slabseeker
Ky
I know it is the switch that is closed when in park but were is it located. Battery is fine crossed the wires on the box on the fender fired right up. 72 Duster is my baby I talkin bout.
Thanks
Neutral safety sw in the transmission. Send a ground reference to the start relay on the inner fender.
G terminal on the starter relay switch is where the NSS connects too.....also...running a ground wire from the G terminal ..the engine will crank in any gear...
