I have the opportunity to buy a 92 GMC one ton with a 350 and only 17,000 miles for $1,500. The catch is it was used as a paint crew vehicle at a state institution and never driven outside the compound of about 300 acres. That means that for the last 24 years it has never been above 15 MPH. It starts and runs good, and has no leaks. The oil is clean and the tranny fluid cherry red. The question is will the transmission still function in the higher gears, or is it stuck in the lower ones from continual low speed driving?
It does need ball joints on the right side from running over curbs I am guessing.
Would you guys trust it for highway use or pass?
