rick1062
Active Member
Hi folks,
I am looking for a bit of help and confirmation.
I am helping my daughter in law with a 1965 Barracuda that has been in her family many years, but parked for about the last five years. I don't have a lot of MoPar experience, but I have turned a lot of wrenches. After replacing the rusted out freeze plugs and a bit more routine work we got it running. Problem is, it won't run well after warmed up (choke open). It has seemed to me like it had a vacuum leak. After rebuilding the carb and checking all the easy stuff I started suspecting the intake manifold gasket. I sprayed carb cleaner around the manifold where I could reach but of course I couldn't reach the bottom side. I didn't notice any change in engine speed while spraying around the intake manifold where I could reach it. As I looked closer I noticed it seemed like some of the intake bolts didn't have the lock washers squeezed down all the way. I checked and the bolts were not too long and bottoming out. I tried a new bolt with a flat washer. That is when I noticed that the flat washer was pinched down on the lower side (toward the center of the intake manifold), but not on the upper outside, so it looked at a glance like the bolt was loose,but that was not the case. So... now I am thinking somewhere along the line someone replaced the heads with later ones. By the way, yes the bolts are 3/8 not 5/16 as I believe they should be.
All of that said, to ask you all if I am on the right track, and if so, what is the best way for me to resolve this. I am thinking, if I could find a two barrell intake manifold that matched the heads I might be in business. I am not sure though, what years of manifold might work on this engine now. This car is not a beauty and is just going to be used for daily transportation at this time, but we do want it to run right.
Can some of you point me in the best direction as to what parts to get, or maybe I am way off base here.
Thanks as always,
Rick
Thanks as always,
Rick
