WTB 69 Barracuda left Upper Control Arm
1969383S
Proud Conservative
North Georgia
I need a "re-buildable" left upper control arm for KH disc set-up (small Ball Joint). I found the original to be welded in upon removal of the old ball joint. Trying to get it finished for re-installation when I get the body back from restoration in august.
I have stock pieces from drum set ups. Don't know if that will work for you.
Left side. Not sure but I believe the disc and drum versions are the same.
