WTB: Drive Shaft 383 4-Speed
UPSTATE340
Rating - 0%
0   0   0
Looking for a decent drive shaft for my '69 Dart, it's a 383 that I'm converting to 4 speed. Let me know if you have something that will work, Car is pretty much stock.
I would just have a new one made, I did and it was done at a decent price. Plus, you know it is good to go, not bent or out of balance!
Sounds good. What price range should I be expecting, and where would I go have this done?
Bump.
I'm looking to buy! I want to at least get my car back on the road. Maybe down the line I'll have it done 100% and have one made.
Thanks.
Can you measure the U-joint center to center dimension on your car? Also, what rear are you using? I have one that measures 45" c-c with the correct yoke on it. I got it with a 72 Duster. The wheel base on the two cars may be different though so it's best to check.
A friend of mine just had one made up for his 67 Barracuda. I believe it was around $225 at a local D/S shop.
Ken
Edison, NJ
[email protected]
