[SOLD] WTB L/A crank pulley (measurement correction)
swinger340
Maine
Looking for an earlier pulley that measures 1.5" from backing to center of the belt. Single or double groove pulley OK. PM if you got something I may be able to use.
cast iron water pump?
Pulley I need is off of a cast iron water pump motor, but mine is not. Mine is aluminium, but I need the shorter crank pulley so belt will line up w thicker fluid damper. I have one off of a 273 that lines up perfect, but it is slightly bent, if nothing else I will attempt straightening it out. What I need is 1.5" from mounting surface to center of the belt. Any 69 and earlier small block should be the same. I got all kinds of later pullies that measure 2" 70 and later
I have an nos double lower crank pulley incase you can't find a used one. $60 plus shipping. The first groove measures exactly 1.5 inches centered from the surface that touches the harmonic balancer. I accept paypal also. Here it is.
That is indeed the baby.... I really do not need NOS. Nothing original about my set up at all... 416 w fluid damper
Figured I would post it incase. Atleast you know it's straight and not pitted or had the whole drilled out....
