If you put something on your wish list, or in your cart at Y1 and leave it, they will eventually offer you a discount.
Year One's part number is L38569.Alright so my m&h engine and headlight wiring has finally came. Anyone that has installed this wiring on a 69 dart or valiant have any idea what wires connect to nss?
Correct but it ties into the headlight harness. I have the nss new as well just don't see where it plugs into the headlight harness.If it is the same as the one I bought for my 69 barracuda, the transmission harness is a separate harness you need to buy also.
Yeah they are just bare, yeah this harness is definitely newer has the newer style voltage regulator.I don't believe that connector existed in 1969. Do you have a mating connector for that on your new NSS harness, or does it have bare terminals on black and violet wires? You probably won't have the little jumper harness I mentioned on the black wire. My car's a 4-speed and I believe that's for the dash-mounted reverse lamp, which you obviously wouldn't have.
Newer style voltage regulator wiringYeah they are just bare, yeah this harness is definitely newer has the newer style voltage regulator.
You are correct b1 and b2 go to the clip that attaches to bulk head.Go here and download the factory service manual for your car. It has the wiring diagrams in it showing where those wires need to go. I'll bet one American dollar they pin directly into the bulkhead connector.
The only real difference between the wiring for automatic and manual is that there's no wire for the starter relay. I believe the violet wire is 12V+ feed and the black wire is for the reverse lamps. On the automatic switch, the brown wire simply grounds the starter relay through the switch to the transmission case.
The only wiring I had left from fire wall out was the windshield wiper motor, you can see where they cut the black and violet wire.Thank you for confirming I'm not losing my marbles.![]()
