YET Another 74 Dart Project in NJ
Steckler108
Member
Started in April 07.... Included is some pictures of last years progress.
i like your fuel tank set up, i might do the same for mine since my original tank is rusted out and so full of gunk i dont think i would evber get it cleaned out.
sweet....I am in the process of aquiring parts for my Single Turbo 70' Dart project....which turbo are you going to use?
Those are not Twins...they are two different variants...:glasses6:
What is the motivation (cubic inch) going to be, and what are your goals?
Nice Progress!, keep us posted...
The work on you car looks extremely sanitary so far. Twin turbos? WOW
They are definetly not twins... Cubic inch is undecided, too much other work going on at the moment. Ultimate goal is to run a mild 8-10lbs of boost, and run 1/4 mile in the 10.50 range. Turbo on right is the one I am going to use, 92mm T4 flange with 4.5 inlet, good to about 1100HP. Turbo on left is way to big for me at current time, 110mm with t6 flange!!
Current status is body work, body work, and more body work!
Thanks for the compliment. Good luck with the project!
