Dang.. that is not good for getting a good handle on this. Any chance you can borrow a dial indicator and degree wheel and look at the lifter max lift and .050" duration? (Both measured at the lifter, not at the valve.... If you do this, you'll need to pull rockers and use a pushrod to follow the lifter movement with very little pressure on the lifter to avoid any lifter compression....or better yet, put in a solid lifter.)Don't know anyyhing about the cam.
Lol, then You'd better find out! One of the #1 things to do to a stock Mopar valvetrain is toDon't know anyyhing about the cam.
Rich Ehrenburg checked & dispelled this a long time ago, mic'd pockets & tested hardness. The MP rockers were no better than the stockers....................MP sells HD rocker arms with a heavier guage pushrod pocket, but for that price Id just get some $150 273 ductile iron mechanicals here on FABO.
yeah, see post #16.....$99 aint bad if your all set up for hydros....Maybe these can handle it..............
Fits: 273/318/340/360
These heavy-duty rocker arms from Mancini Racing are quality replacements for your factory originals. They feature thicker cross-sections in the pushrod socket. Left and right refer to rocker offset, not to the sides of the engine or cylinder head.
Includes 16 heavy duty hyraulic rocker arms
Mancini Racing Steel Rocker Arm Set, 1.5 Ratio
