Z Bar Lubrication
A340
Central OH
When you re assemble the Z-bar with the nylon bushings and ball studs, do you only lubricate those parts or do you pump the whole shaft full of grease? Any particular grease, chassis, white lithium, Wheel Bearing, etc??
I use white lithium grease and just dip the whole ball in it put the nylon parts on then lube that up real good and put it in the shaft.
Use a non-petroleum based grease like lithium and grease the ball joints leaving a little reserve in the torque shaft tube.
If you have a grease gun, drill and tap for a zerk, then load it up with the appropriate grease...
