240 gordy
Couple of questions re the TTI (and stock) Z bar. There is a thin spring that fits in the 2 holes on the frame end of the Z bar and I believe it keeps the bar from moving in and out too much. Question---do the 2 spring ends fit into the Z bar and go below the bushings or in the groove in the bushings to stop it from moving.. Next question ---The rebuild kit comes with 2 rubber end washers. How the hell do you get these washers over the ball on the ball mounts???
