Originalowner73 340duster
Which is a good ignition system to go with my 340.. upgrading and looking for someone who has done one and is very satisfied
Petronix Ignitor II or III with matching coil . This eliminates the ballast . For the street get the vacuum advance unit .[/QUOT
Ok thanks..What's the difference with using vacuum advance??Pace Performance's ready to run. Same as the MSD except the price. 3 wires, +, -, Ground. Done.
??? Vacuum adavance helps mileage and drivability. You can run one without it if you wanted to. Are you onthe street most of the time? Or is this mostly a track car?Ok thanks..What's the difference with using vacuum advance??
Street..hard drives tho??? Vacuum adavance helps mileage and drivability. You can run one without it if you wanted to. Are you onthe street most of the time? Or is this mostly a track car?
Ok awesome.. thanks for the info.really appreciate itOK, you have a street stripper. Cool.
IMO, you would want the vacuum advance as to help with a cruise. Be it down to 7-11 for coffee and bread or out to Bellmore, Oakdale for a showing. It will help mileage and help deliver good street manors.
Performance will not be limited.
MSD ignitions don`t use a ballast resistor either. I have run MSD`s on 4 diff hotrods, 1/drag only, 3 street n strip cars, and never had a problem w/ any of them. Hunt the best price on anyone tho!Unless you enjoying spend a lot of cash, look at the $45 Ningbo ready-to-run distributor (ebay, Steve White Perf and others). Many posts here. Add an e-core coil for hottest spark.
