- Joined
- Mar 17, 2018
- Messages
- 13,592
- Reaction score
- 31,016
Super thanks, I have put my research analyst, head of procurement on it! That looks intriguing.
It’s already been decided weeks agoHeart says Lions, head says 49ers
They work great. We have them at workSuper thanks, I have put my research analyst, head of procurement on it! That looks intriguing.
Morning Tike.Good Morning Freddy
Ooooo Unless it's only a few years old, probably notI have a question for all of you fart smellers.....I mean smart fellers. I am turning a van into a camper so I can drive to the North upon retirement. I have a leak in the AC thats not the problem my problem is alot of the metal lines have rust all over them. Is there a place I can order replacements?
It;s a 92 Maybe I will go to the junk yardOoooo Unless it's only a few years old, probably not
One time (long ago) when I was driving truck, we had to call in 2 times a day. I was in Ephrata, PA and there was a circus in the huge parking lot of a mall. So I am in the phone booth calling in to see if there was something I need to reroute to pick up and I am on the phone with the dispatcher when the elephant got loose. As he went by I said to her...you are not going to believe this but an elephant just went by with a bunch of people chasing it. She never missed a beat and said "is it pink? Why don't you just come home but maybe you should sleep it off before you start". Even to this day when I see her she will ask me if I have seen anymore pink elephants
Beer and saws alls and wires do not mix wellDumb mistakes here yesterday. Probably too much beer with my cousin. Needed to put shocks on the front of his 2000 Jeep Grand Cherokee. Tops were rusty so I used a cut off tool to cut the tops off, no issue. Got the shocks on it. Went to fire it up and it won't start. After further investigation, I see where I nicked the wire loom nearby the right shock. This wire loom goes to the ECM. Wtf. Didn't cut any wire all the way through but I think a couple of them arked when he tried to start it because it sounded like it wanted to start initially. So now it's stuck here. Found four bad fuses in the fuse box under the dashboard, was quite sure that was all the problem but no. Checked. Checked all the rest of the fuses and relays in the under hood fuse box. No issues there. Still no start. I think it may have fried the ECM .WTF.![]()
Depends on the van. And even then, some local hvac shops can get lines for them or make themI have a question for all of you fart smellers.....I mean smart fellers. I am turning a van into a camper so I can drive to the North upon retirement. I have a leak in the AC thats not the problem my problem is alot of the metal lines have rust all over them. Is there a place I can order replacements?
A few years ago I was installing air lift air bags in my brand new Toyota four runner. Week old. Well I had to run some wiring thru firewall and thought the rubber surrounding the main wiring harness was a good place. Long story short it was not. Drill slipped nicked the wires . No way to repair harness in vehicle. I had to remove the main harness from vehicle to repair. Well when Simone got home she saw our brand new car in pieces. Was not happy.....beer was involvedBeer and saws alls and wires do not mix well
Can't like that one, whoops! When I was working in a Motorola shop we had an installer do the same thing to a Prius for a school district. Tried to start the car after the install, dash said "Problem" and wouldn't start. Had to be towed to local dealership for harne$$ replacement.A few years ago I was installing air lift air bags in my brand new Toyota four runner. Week old. Well I had to run some wiring thru firewall and thought the rubber surrounding the main wiring harness was a good place. Long story short it was not. Drill slipped nicked the wires . No way to repair harness in vehicle. I had to remove the main harness from vehicle to repair. Well when Simone got home she saw our brand new car in pieces. Was not happy.....beer was involved
Wow, wondering where those will exit at.PSA for Coffee Shop. Schoenfeld headers will make any of their small block chevy headers with BB Mopar flange if you fond a set that works for you. Much cheaper than most Mopar headers too!! These are for the Charger
Remmebr I am putting the firewall back about 8-9" so this style works for meWow, wondering where those will exit at.
Looking real good Eric. Would love a ride in it when it's on the road.Remmebr I am putting the firewall back about 8-9" so this style works for me
Need to find a shop that can make the lines or replace with hose. Mastercool makes a tool for flaring lines. Mine does a couple different ac flares.I have a question for all of you fart smellers.....I mean smart fellers. I am turning a van into a camper so I can drive to the North upon retirement. I have a leak in the AC thats not the problem my problem is alot of the metal lines have rust all over them. Is there a place I can order replacements?
