I took my new 2010 Dodge Ram back to the dealership for undercoating and a oil change. It had only 1500 miles on it but I like to get the oil drained out to remove any metal particulates or tools left behind by the factory workers. Two days and about 20 miles after I got it back home I noticed oil running out from under the truck, when I looked under it I found the drain plug three turns from falling out. With oil on my cement drive way that I clean with a tooth brush and my new Ram with oil running out of it, boy was I some pissed and I can take a lot but that was way to much. After I tightened the plug I found it 4 liters low it holds 7 when full. Check out the picture how far do you think it would have gone before it fell out and screwed the motor. :angry7:
Kenny
Kenny
