Need a new drive shaft what is everyone using
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
My drive shaft has a wicked shake and I was wondering what everyone is using for shafts. The local shop i was going to have do the balancing said they would have to install new u joints in order to balance it properly. So I went ahead and installed a new set. They are 7260 u joints (315G NAPA). Brought the shaft to them and he said it wouldn't balance because of a dent and a missing weight. They wanted 180 plus the cost of the tube. There is a shop in Sioux Falls called drive-line specialties that everyone seems to recommend and they will do it for 125 (price includes the tube)
The engine makes a little over 400hp 2800 stall full manual, 8 3/4 3.91 suregrip. I race it at the track with slicks 2-4 times a year.
Drive-line specialties originally suggested I go to the 1350 u joint. $250 would include the new front yoke, new shaft but I would still have to buy a new rear yoke.
Don't really have the much ching laying around but I would rather not waste 125 putting a weak link in my build.
What do you guys think 7260's with a new tube good enough.
I was also looking into u joint girdles for the rear yoke. anybody using these http://www.jegs.com/i/Moroso/710/85850/10002/-1
Picture of what I don't want to happen (not my shaft)
Sheeet,you can't get that one straightened out:bootysha:All kidding aside,IMOP save your money and get the good shaft with the bigger joints.That way when you step the power up later{you know you will!}you have already eliminated one of the weak links.Besides,,,,,,,,,,,I like bigger joints.:flower::rolleyes:
You had a gm shaft in your car? ? ? no wonder why you had a problem... 3R series and t350 slips would usually cause a issue in a Mopar
A dent and a missing weight doesn't mean you need a re-tube unless it is in fact bent...
95% of the time a dent is not a bend... and it can be balanced...
Do you have a pic of the dent ?
If you had to make a new shaft then i would do 1310 x 7260, using the spl series joints you could double that hp.
Not a GM shaft. I will take some pics tomorrow. Drive shaft is at work.
I bought a set of girdles like that in the mid 90s. I don't remember if I ever used them or not. I don't think I did.
Man, if I had all of the money I spent on parts that I didn't use over the years, I'd be um... Well, less in debt, I guess.
That shaft in the picture kinda looks like GM if you had 7260 series.
I would leave those girdles at jegs too
igot a 3inch chrome molly 1350 joints no slip yoke had one for 275 at my door they said it would be good for 1200 horse 48inch long
Got a 3" custom made by a local company with 1350 u-joints,thing i paid $250.00 well worth ih for the peace-of-mind..
custom made with yokes? for 250
The front and rear yokes alone are 250
we have a local shop here in spokane called murls drive line... he did mine it was 120 that was shortened balanced new u joints painted ready to rock..
Keep the good info coming. I,m considering an aluminum one for my b body. I also appreciate everyones input on this thread.
1350 shafts are used in a lot of 1 ton trucks. What are some pros and cons of cutting down one of these bad boys. The local salvage yard treats the shop I work at pretty well.
I measured to make sure the shaft I was using is the right length. Using the 1" rule it should be 47 7/8. The shaft I was going to use is 46 5/8!
The manual says 47.81 (47 13/16)
What vehicle uses the 1310? I found the 7290 conversion 7260/7290= napa#347
When you lose the factory shaft and build a new one you either use 1310, 1330 or 1350, detroit went under a while back, and even though AAM seems to be following in there footsteps with the way there making joints.
So when you get a new shaft if you have 7260 series slip and end yoke the driveline shop would/should build you a shaft with 1310 series weld yokes and use either the 5-353 or the spl 5-788.
That will keep you from needing a new slip and end yoke.
Anything at napa is china junk, find a local mom and pop parts store that isn't influenced by china
Thanks for the info. :cheers: This seems to be the best idea ($ to strength ratio)
I built my shaft for my car, no lightweight at 3800 and 550 before anything else... I got plenty more out there the same way.
I would go AL if i was you, you'll get more perf out of the AL, every car i have done has lost at the very least 7 hundreths.
Could I use a viper drive shaft/slip yoke. Its aluminum with 1350's just have it extended and buy a rear yoke?
1350 Series 727 auto & A833 manual and T-56 VIPER with 29/30 spline output
The slip yoke barrel is shorter by almost 2 inches though?
The slip length is ok, that would be dealt with when building the shaft....
If the shop has the AL tube for it you can, the viper uses 3.5" x .120 wall spicer shaft and .125 w for the half shafts
