6/26/69 complete 340 built
340plot
the bushy bush
va
Rating - 95.8%
23   1   0
i have a nice .030 over 340. it has a huge cam, unknowned specs. 273 adjustable rockers. mp pistons. they were 12:1 comp, but milled down to 10 to 1 specs. have w.p, timing cover, new double roller timing chain,deep sump oil pand and pickup on new h.v oil pump.
also included is a set of j heads that have 2:05 1:60 valves. double springs.
i bought this engine in a car, and just found a stock 340 with 4 speed setup. he will not break up his stuff, so i have no use for this engine.
every bearing in this engine is like new. the engine sat 7 years in the car. all the rings wer perfect, as is the cylinder walls.the crank is perfect. did not even need a polish
this engine is ready for new bearings(just for security), gaskets, and valve seals.
also(for couple extra bucks) have a old school holley strip dominator and 750 holley carb that was on this engine.
also for extra have a fully rebuilt 727 with shift kit, and high stall coverter between 3500-4500 stall. i have to pick it up from the trans shop. i had them go over it for a clean bill of health.
1800 for all
1600.00 for engine and trans
1,300.00 for engine. will not sell other stuff until engine sells
also take partial trade for a body tti or dougs headers
what do you mean of the tops? there is a pic up there.lol you mean up close?
hope this helps
will also sell the heads seperatly for 500.00 plus the ride
it was 3690825, which the number came back to a m.p 12:1 piston
Would you be intereseted in shipping. Where are you at ? My zip is 54484 .
i have no problem shipping it if you set it all up.( you calling the shipping place. do you want engine/ trans/heads and everything? or what do you want?
mudpup, if you are serious, i am heading to bad axe michigan on wensday night, and could bring it that far for you to meet me. i would just charge you like 40 bucks for gas
well, i forgot to mark this as not for sale any longer, as i just located and picking up a 72 dart in the morning for this powerplant to go into. sorry
mods, please delete
