Weber DGV carbs YOUR Opinions??
805moparkid
Slant and AFX Guy
Anthem AZ
so i have a pair of these downdraft weber DGV's on my 240z... never seen them before!
are they any good? should i find a set of sidedraft SU's instead?
thx guys
The DGV is a good carb. It is a progressive 2 bbl and popular with the /6, crowd among others. The carburetor is still sold and there is aftermarket support for it.
My experience with SUs exercised my repertoire of epithets. When properly sync'ed they worked fine.
If you're looking for a carburetor for an old Z car, how about a fabricated manifold with 3 DCOE 38s on it. The DCO is a sidedraft non-progressive Weber.
Expensive. Are you thinking of running them on a Mopar?
From the 1980 Chrysler K cars to the 88 Honda Accords the factory carbs were crap. Webers conversions were a bit pricey but worth every penny.
they are on my 72 240z and i always ad the Su's so iwas thinking of selling them and going back to the su's
I don't have tech knowledge about them but I do remember clearly back in the '70's z-owners ditched the SU's for Webers, it was a very popular upgrade.
I had a 71 240 myself. It had the SU's and while a lot of people don't like them, mine didn't give me any trouble. You need a relatively inexpensive flow meter to balance them out correctly, but it ain't hard to do.
yea i remeber... i had another 72 with the SU's and i loved them! im ditching these webers for the round tops...
how much do you think that the dgv's with linkage, manifolds is worth used, rebuildable??
I don't know man. Been a while since I messed around with it but 350-400? Just a guess.
I'm looking for three Weber 32/36 carbs for this :snakeman::snakeman::snakeman:
I have two carbs off of a 59 volovo that I think are solex carbs that I want to use for a side draft /six project.....that mainfold is the ****..where did you get it..
I got it from another member that lives pretty close to me. It's going on the 48 chevy.
i got the car from Gf's uncle, cool guy, he said that he used to drive it daily but stopped driving it due to tickets:-D, so it sat for about a yr, till i went and picked it up this month
ok here is your pics
the intakes are cannon
little tags say as such
front carb
Weber
711F FB
A 1G6
Rear Carb
Weber
711F FB
A 1G8
You have a conversion kit made by Cannon Manifolds (Pierce is another common system, same idea). These conversions have been popular for years to replace SU, Hirachi-SU, and Zenith-Stromberg carbs on Z-cars as well as most popular british engines. I personally have a pretty low opinion of them, but oters may feel differently. Note that I have a high opinion of the Weber 32/36 DGV carb.
Here's my take. The kits first were marketed to the Triumph TR-6 crowd as a "replacement" for the often maligned Zenith Stromberg carbs which many saw as "smog control" mostly because the rest of the world got mechanical fuel injection. The injected engines made about 50 more horsepower. Why? The US spec carm engines had 7:1 compression, the home market had 10:1, a far hotter cam, and a MUCH more aggressive timing curve. The injection system itself was maybe worth 10 HP and easily cost 5 mpg. The Hitatchi made SU's on early Z cars were looked on negatively for most of the same reasons. Now, by the early 80's these factory carbs and distributors were beginning to wear out (or had been monkeyed with) and the cars performance/economy suffered. So Cannon, mostly through slick marketing, came up with a solution: "Dual Webers". Not the performance DCOE, IDA, or IDF carbs that Alfa, Porsche, Fiat and many race cars had been running since the 50's. But a simple off-the-shelf universal carb. Fine, fair enough. You can probably thank EMPI for starting the DGV craze in the 60's on aircooled VW's (to replace 1 bbl Solex carbs, which WAS an upgrade). Back then, most "car guys" had some experience tweaking VW's, so if it made their VW run better, why not their Triumph/MG/240Z/Datsun 510/whatever? It typically made them run "like new again". Not because the DGV had any more performance potential than an SU, but because it wasnt worn out or hopelessly screwed up. A new Mallory or Bosch distributor helped a lot too (probably more than any carb could). Was the car faster? Maybe. Also, SU and Zenith-Stromberg carbs parts were getting hard to come by.
On my last TR-6 I had a similar setup for a while. Ran OK. Put a set of rebuilt Zenith-Strombergs on it and it ran as good, or better. Put a 3rd Stromberg on it and it ran far better (by this time I had a far warmer cam, 10.5 compression, headers, aluminum flywheel, and Mallory dist). Sold the DGV's to a guy who had worn out Strombergs (and didn't know sh*t about cars) and he still runs them today.
I guess what I am trying to say is, the DGV's are really no better or worse performance wist on a stock engine. Those adaptor manifolds WILL hurt you eventually at higher RPM, if you start modifying the engine. Like a 1 3/4" SU, they will support abour 50-75 HP per carb. If it were mine, and the DGV's were in good shape I'd just run them. I'd even clean/kit them if need be. If you are planning to really increse the power of this car, save up fior a set of triple DCOE's! Check around the Z-car forums, probably get a similar response.
wow! lots of great info in that post! thank you... im just looking to make it my daily with great suspension and an rv style cam, nothing major...
Lynx was an Aussie company.....I have a triple Weber intake for a /6....and the 3 DHLA45's for it too....going on the Nostalgia Drag car...62 Valiant sedan
I'd be looking for 3 SH HS6's if I had that manifold! That pic shows the rather diabolical S-bend manifold adapters that wipe out any performance gains the Weber may provide.
yea kinda strange that everyone of these DGV's kits have them... for side draft conversion of course
