How do you properly align the speedometer gear to the trans on a 833?
It has different settings for the tooth count.
thanks
thanks
When you plug in the speedo adapter turn it until the pinion hits the gear on the output shaft then back it off ever so slightly so your speedo gear doesnt wear out.
