is it worth replacing ?
lebdog74
Active Member
Osterburg, PA
I believe I have my starting problem narrowed down to the magnetic pick up. i am wondering if its worth replacing only the magnetic pick up or should I just get a new distributor? Also the reluctor looks to be on the rusty side, not sure why though its only about 5 yrs old, so i might need to replace that as well. any suggestions
I threw my stock one away (actually I gave it away) and now have and msd unit (the same one autoxcuda is using in his cuda.
the distributor is currently a mopar performance. it came in a mopar performance kit with ballast and ignition control module
Here ya go....
It probably wouldn't cost much to fix what you got but on the other hand waggin is showing you the **** that killed Elvis!
whats a pick up cost? 10 -20 bucks? fix the thing.
Damn, I came in a little late on this one. I went through 2 Cardone dizzys from autozone and just ordered a Proform for $132.00. I'd have rathered had the Accel.
That's a good deal.
