Early Dart (64-66) 22" radiator?
65Valiant310
Anyone know if the 64-66 Dart 22" radiator was the same one used in the barracudas?
I met a fellow with an early dart, and he had a 22" in there and he said it came that way, yet the top tank was not round, it was square.
64's came with smaller radiators due to the core support size. 65/66 Darts, Valiants, and Barracudas with the 273 came with 22 inch radiators and they were all round tops. Square tops came a lot later (but can be used in the early A)
My 1964 Valiant had this, aprox. 18 inch wide core.
Yea his 22 incher was a square top so it must have come from a later model.
I always heard the square tops are too tall to fit in early a's...maybe I will try it out.
hmm...
Champion makes one for that application. It is their #1635
According to their info sheet on it, it fits:
63-66 Dart, 66-69 Charger, 65-69 Coronet
63-67 Dodge Station Wagon, 63-65 Dodge 2 Door, 63-67 Fury
65-67 Satellite, 63-67 Belvedere, 63-67 Plymouth Station Wagon
63-66 Plymouth Valient/Signet, 63-64 Savoy
CORE DEM 18 1/2 x 21 7/8
OVERALL 23 3/4 x 26
HOSE LOCATIONS Off Set-Driver / Lower Driver
HOSE FITTINGS IN- 1 1/2 OUT- 1 1/2
TRANS/HEATER YES
MOUNTING TYPE BRACKET MOUNT
BRACKET SPECS Vert - 14 3/4 Hor - 24 1/2
Crazy part is, he had the lower outlet on the passenger side, which is what I need, hence all the questions I asked him about it.
OVERALL 23 3/4 x 26
TRANS/HEATER YES
When I parted out a 65 Coronet I had, I tried the radiator in my 65 Dart and it was too tall.
The bottom hose location is opposite to /6 V8 applications as well. V8 is on driver's side and /6 on passenger side, as mentioned before. Although, they may look similar (round-top, near-center top hose location). So, you've got to be careful buying off of the internet. It may match make and model on a search but, pay attention. Some people out there don't know enough about what they're selling to be specific enough.
