holley metering block questions...
stroker_valiant
Tulsa Oklahoma
I have a Proform main body, the smoothed venture type. It has changeable air bleeds, so I’m going to put it to use. I picked it up from a buddy for free, it has no casting numbers to show what cfm it will flow. I am currently running a Holley 800 with a Proform billet base plate. My current Holley does not have the four corner idle adjustments and has a choke tower on it, so I want to get rid of it. Is the conversion to the four corner setup just as easy as buying a Holley metering block with the adjustments on it? Is there any kind of matching of the metering blocks? I assume this main body is set up for the four corner setup, but I don’t know how to tell. Below are the links of the parts I have, but I’m not sure if this is EXACTLY the same main body, since it has no identifiable casting numbers. Thanks for any help!!
http://www.summitracing.com/parts/PRO-67100C/
http://www.summitracing.com/parts/PRO-67155/
http://www.summitracing.com/parts/HLY-134-62/
[/SIZE][/FONT]
as long as the main body and base plate support the 4 corner idle...yes...you need a rear metering block with an idle circuit...
you might want to take a look at the billet metering blocks from proform or quick fuel tech...
I was looking at the nicer blocks, but figured since I allready have the front block, why get two more just to have a finer emulsification? It is a stroker, but more of a street ride. My main concern is that I dont know how to tell if the main body supports a secondary idle circut. If I post up some detailed hi-res pics of the main body, is there anybody here that identify it for me?
So I called Proform, turns out I have a 750 mainbody, and it does support the secondary idle circuit. Since I want four corner idle adjustability, the Proform tech recommended me a good metering block (link is at the bottom of the page). I thought I had an 800cfm mainbody, but I am actually happy with it being a 750, being that the car is primarily a street car; I think I will be better off with a slightly smaller carb. I’ll just have to tune it out and jet it properly. They also recommended I run a secondary power valve plug (which I already am on my 800).
http://www.proformparts.com/product...BRATION_BILLET_METERING_BLOCK/category_id/187
glad someone answered the phone...I have a billet base plate i have had issues with from proform...
went i get home i will call them.
