Andy White
I was at carlise and noticed a few of the cars had been painted underneath as nice as the top. any one else doing that?
thats cool but i imagine a lot of work to keep clean if you actually drive your car.
Certain areas of my wheel wells were done with Lizard Skin, then resprayed over it. Body guy did this cuz of the dirt road I live on.....Is it correct? I cleaned mine up some and used rubberized undercoating similar to lizard skin.
Black hides rust and scale, if the metal is perfect then body color is best. Factory just used black cause it was cheaper to paint
yeah, hard to believe, isn't it?!?Remember, the cars were dipped in primer/rust proofing after the body was built.
Any paint that was on the bottom of the car was just overspray from when they painted the lower portion of the body.
They did apply undercoating to the wheelwells to cut down on noise and cover up any primer or body color that would look tacky.
Factory undercoating was a 2 edged sword. It protected the metal but after a while it got old and cracked which gave moisture a good place to sit and do serious damage...sorta like water under a rubber floor mat.
