The first 2 pics are when I picked it up, the last one is when I got it home. I've taken all the stickers off the windows and done a few things that it needed. I have a new signal switch on order to get the signals and brake lights working right, and I have a good stock hood to paint and get rid of the fiberglass cowl induction hood. I also ordered a bumble bee stripe to go around the back. It has a full cage in it and was being used for drag racing, but I want it more streetable, so I need to replace the 4.56 gears and spool center section with a sure grip and 3.55 or 3.91 gears. I replaced all the ball joints and tie rod ends/sleeves, and put in a new radiator and electric fan. The ball joints and outer tie rod ends were not right when I got them at the autoparts store... they were smaller than what was on the car, but looked the same. After some digging around, it seems that someone changed to brakes/spindles from a Dodge Polara. I got them all fixed now, and aligned. It drives great (except the spool rear end) and the 340 is built pretty nasty with 360 ported heads.
