SRT_DSTRHOLC
cam at 251-260
ABDC of 53 put in 2 deg more to 55 or 4 DEG to 57 to get 8.7 DCR with KB calculator, but what ever brian recommends is what Im running on pump gas!!!
10.3 SCR compression
8.6-8.8 DCR depending on Altitude
ported RHS heads from Brian 290CFM at 550
4in Scat Crank
Forged Pistons
360 bored .40 over so 410
Ported Air gap by IMM
Looking to run on 91 octane
Transmission:
904
4200 Dynamic stall
4.10 gears
Frame connectors
Ss Springs
Pinion Snubber
Might be putting in a 6 point cage also
Car will be weighing in at around 3000-3100
Want to know what you guys think..This setup has been beaten to death with Brian and prolly will be buying the kit from him. All thats left is to buy the parts check them out and put them in.
4in Scat Crank
Forged Pistons
Transmission:
904
4200 Dynamic stall
4.10 gears
Frame connectors
Ss Springs
Pinion Snubber
