1966DartConvertible
Hi all
I hope some of you here have an engine in your backyard that you are not using, that can be sold separately as parts.
My '66 Dart is currently running a non-original carb - Solex from a Land Rover S2, and is running very rich (black smoke at the back)
Also, and more importantly, since this is a non-original carb, the kickdown linkage cant be connected!
Here are a couple of pictures:
As you can see from the 1st picture, the kickdown linkage is not connected to the carb. And the 2nd picture shows that the throttle turns clockwise to open and the kickdown linkage needs to go DOWN as the throttle is opened. So I cant just fabricate something out.
Hence, It would be great if anyonebcan help me out getting the original setup. (Dont have to be everything, even if you have the carb only, lemme know.) THANKS!
Syed
Syed
