Mad Dart
Nothing to see Here!
You should duplicate it and sell it as a kit.
Sounds interesting but I don't think I would ever do that. I barely can scrape up enough time to finish this one.
When I first started on this project I thought for sure I would knock it out quickly. I got alot of the fabrication done in the first couple weeks. As the project went along things had to change. I had problems with Hood Clearance and everything went wackoo. I did not want to put a scoop on the car so alot of things got changed. It is funny how you start something with the end result in mind and as you go along you have to go in a different direction and when you do it changes alot of little things.
Baddart;Dang Louis that thing looks evil. I love it.
Thanks John, almost there. I am getting nervous Oct 6th is coming quickly for the Dyno.:toothy5:
There is a guy on theturboforums.com with a 427ci SBC Twin Turbo "Just Like the ones I am using" with CO2 that will be on the Chassis Dyno right around the corner from my office on Monday at Cunningham Motorsports. I am going to stop in there to see what that one puts down on the Rollers.
