transgo tf-3 instructions
mod38-1
Wondering if anyone has instructions for transgo tf-3 kit? I searched and i cant find them anywhere online. Thanks
The year of kit is unknown. It is from a friends car that had trans problems and all he knows it is a tf-3 kit in valvebody. So i am looking for some instructions so i can go through valvebody for him.
There HAS to be someone on this site with TF-3 destructions.......
Here are some pics of the valve body. The only things I can see different so far without taking apart is the pressure regulator spring is blue and there is what looks to be a stiffner plate added to the rear.
.............If there is no other plate bolted to the bottom u have 1 of the 1st kits from the late 70s early 80s............the triangular plate is for the manual shift, it is foreward pattern...........the pr spring is only supposed to be at 6 turns maximum, looks to be 10 or more..........what kinds of issues was it having..........kim..........
It had converter failure that caused debris through trans. Valve body needs to come apart to be cleaned and inspected. I would like the instructions to know it is properly set-up when putting back together. Thanks
Finally called Transgo, and they emailed 'em to me, so I passed 'em along to the OP
Anyone else wants them, shoot me a PM
..............Good luck, hope it works out 4 ya......when u get into it, lmk as there is some things that i've learned along the way.......kim.............
