matty wardle
mopar dedicated
hi guys,
new on here but want to post my combo on here and see what u think
400 block 4.375 bore
440 source rotating kit stroke 3.75 (451 cubes)
440 source stealth heads
comp cams xe285hl -285/297---241/247@50----545lift
mopar m1 single plane
ras or comp cams rockers
comp 10.0 to 1
1 7/8th headers
3000 stall
4:10 rear
motor is going in my 73 barracuda,around 3500 pounds,what carbie?
do u think this will be ok,is the cam too big,will it be very drivable on the street,as i want to drive it a fair bit and race it on occasions.i havn,t bought the cam or rockers yet and am open to suggestions if u think i should change anything.what i am looking for is maximum power from a hydraulic cam,want it to be street driven,run 11,s if possible,not run hot and not be a pig,am i on the right path,do u think i will have to port the heads with this cam or use them out of the box?
comp 10.0 to 1
1 7/8th headers
3000 stall
4:10 rear
