I would have to add everything up, but I'm close to $20,000 now, I'm sure. With the original purchase of the car as a starting point, I added:
408 stroker
2800 stall for 904 tranny
new 200R4 tranny, adapter, needed extras, new stall converter
Dana 60 w 4.10
mono leafs
caltracs
floor shifter
line locs
adjustable strut rods
new wheels and tires
front cross drilled rotors to match the rear discs
new tach
new used dash cluster - twice
new dash pad
used hood to cut and mount hood scoop and paint
go wing
new comp cam for original 318
new body seals
new Hella headlights and Daniel Stern headlamp wiring harness
new horns
new fan switch, headlight switch, turn signal switch and dimmer switch
hugely expensive chrome sport mirrors
It hurts to look at it this way, but you know ... I took it out of storage today because it was 50 degrees in January in Minnesota. I came sideways out of the storage facility's driveway an left a ton of smoke and burned rubber behind me. Right there and then I decided it was all worth it.
