ramman7284
when i bought my duster i bought a mopar m1 intake for small block im curious if it will fit under the stock hood it will have dp holley and a low air cleaner
Use a Drop Base Air Cleaner and you will be fine!!
use a drop base air cleaner and you will be fine!!
thats what i have and will use but im also curious as to what rpm range its runs good at and what alot of ppl use it for
ok so it shall do wonders on a 318 that built with these goodies
eddy performer rpm heads #60779 (ive been hearing bad things about these)
hooker comp headers #hok-5901hkr
holley 650 double pumper
lunati 268/276 cam #60403lk
eddy true roller chain and gear set
kb167 flat tops depending if i have to bore the block a little
and i hope to put a t-56 6spd behind it
