Someone here replied previously with that same thought process...the only forged slugs I know of that would be worth a damn for a 383 would be the Diamond flat tops...nice close to zero deck pistons with healthy reliefs big enough for 2.14/1.81 valves...but you still need small chamber heads...
Downside? They're $600...unless you guys know of some more forgings available elsewhere...seems like there are tons available for 383 strokers and for 400s, and 440s...but nothing nice for a regular old 383
If you run closed chamber heads, and stick to the 2.08/1.74" valve sizes, a stock forged replacement flat top can hit 10.0/1 comp pretty easily. These pistons don't have valve reliefs, and will limit you to right around .510" lift. With well ported heads, 10/1 a .500"+ cam, good intake and exhaust, I could easily see 500HP being made, which isn't too hard to take.
