Holley doublepump
lead69
hopeless car junkie
Vancouver,Wa
I had this on the shelf for a while now and decided to sale it,very nice low miles holley double pump converted with a proform main body that I got from a buddy.Jetted 72/78 I believe with the 6.5 power valve,everything is like new,throttle shafts are tight,plates are not drilled,looks really nice but like all carbs expect to tune it for your engine.asking $250 plus shipping from 98682,thanks.
It would be right around 800 I believe with the pro form body,it does not have a choke since its contoured like the h.p. series carbs.
I know just about everyones broke!,I will do $200 shipped usps in the U.S.,thanks.
Do you know for sure it is a 800cfm ?
It is supposed to be 800-830,it measures out to a 750 baseplate (1 11/16 throttle plates) with a slightly larger venturi size for the proform body (1.4 vs. the std. holley 750 which is 1.375).Its obviously larger than a 750 but who knows really how much unless its flowed,I got the above cfm ratings from the tech line though.
if it does not drip or leak it would be interested be perfect for my 408 i do think
write me please
