snapetwo
For those of you that ARE NOT, using alterkation or something similar.
What TBs are you using under the new hemi 5.7 or 6.1?
I've been in contact with Mike at PST, and he suggests running the 0.096", over the 1.03".
" As far as torsion bars go I would say .096" is probably the best bet. They are a stiffer 440 bar that retains the factory clocking so you can raise them a little higher if needed. The 1.03 bars are clocked differently and with a lot of weight would sit low. "
I won't pretend to know what clocking means.
