1962 Dodge Lancer Drag Car 451 Stroker Trade ??
hotrodhoodlum
X Nostalgia Drag Racer
Bartlett IL 60103
After a couple more hole shots I just did Screw the doctors Im keeping it ....LMAO...............
very interesting car, PM me more info including price engine spec bottom line price ty steve:burnout:
Sent you a PM
Thanks
The Original owner passed away before it was totalty finished .The Car was sold and resold once . It needed some minor stuff before it was track ready It was was worked on by Jim at Pugh's Auto Service in TN He is a Mopar Specialist he checked all out and did some minor work to it like Oil Filter system, Tune Up, Jet Changes, Rocker Adjustments, all fluids changed ETC . It was raced in summer of 2012 about 4 times to get the bugs out in ran 1/8 mile on foot brake very mild shift at 5800 and ran 7.02 to 7.07. Trans brake was never used . It lifted the front about 10" and ran very strong . There is a ton of time left in this set up to go faster if you choose to. The set up it has now is for low maintence and dependability to go round after round.
With Brake and higher shift at 6500 to 6700 FYI engine will take over 7000 rpm shift it will run 10.90 s to 10.80 s . It has a very mild roller Cam with a 3500 stall . You put in a Different cam and a higher stall your looking at low 10 s.
I have been working on it to pass N.H.R.A Tech RT 66 Dragway in Illinois very strict . I have installed a new S.F.I Balancer, New Belts not installed trans blanket,not installed . I Rewired it with new control panel, New Battery and Drag BatteryBox, Starting Detailing interior and the entire car New side windows . I wanted to take headers off to to blast and repaint and remove intake manifold to bead blast and polish . It will need longer studs in the front to pass tech that’s about it .
Title was lost by the wife but it does and a valid VINN Tag to apply for a lost title could be put back on the street very easy all lights in installed just needs to be wired
1962 Dodge Lancer All steel paint its an amateur paint Job and a 10 footer . Very Minor Bubbles in paint on rocker. Surface Rust in Paint Its a race
Car not a show car .
All Aluminum Interior
Full tubed rear
New Simpson Belts
New Lexan Side Glass rolls up and down
Square Tube Chassis Mustang II Front End
Disc Brakes
Dana Rear with 456 Engine
451 Stroker Roller Engine
Pump Gas Engine
727 with Trans Brake
Quarter Stick Shifter
Last Chance this car will only be offered utill Monday 11/19/2012 when the E Bay auction ends after that Im keeping it and racing it . I will only look at other race cars for Trade or street and strip cars I have recieved a ton of trade offers but I am not interested in a stock vehicle .
