Paint
Painted the engine bay 3 runs(weather was alittle cold) but they can be fixed.Still need to paint K framE(etc).
Sanded and sanded and sanded the steering coloum and polished it looks good for a original 71 sterring colum.
She looks and sounds good.
What size are the tires front and rear?
Did you build that engine start up stand yourself?
If so post a couple of pics without the engine on it if you dont mind.
You have the gears in my head spinning, I have two fresh built motors sitting that I would love to hear run, a 340 and an aluminum headed 360.
Wow that looks good I like the pumpkin silver might copy that. Thanks for the size of the tires.
I think you can notch the 7 1/4 to work on an 8 3/4. They are the same for and 8 3/4 or Dana 60 and I think Dana 70.
anyone now a good front end rebuild kit semi cheap like around 300 dollars
off topic... clutch flite? is it still in your car?tell me more,always wanted one...NIce car, better off than mine, it was a 1972 dodge charger rt, had it for two years, got tired of fixing it up and then sold it and used the money to buy my current car, a 1967 dodge dart gt with a 440 and a clutch flite 727
Geeze kid. You've done quite a bit of work there. Makes me, the college student, look bad. I can barely scrape up time to fix my Dart just to drive (hopefully during winter break). And how many times have you changed your wheel and tire combo? They just keep on getting bigger and bigger. Lol.
