proportioning valve??
69DARTS
69 Darts Rule
indiana
does anybody sell them new
73 up disk brakes front
drums rear
manual brakes
I call it the split block..... down on the frame, but yes you can
buy them new from Inline Tube, in Detroit, Mich. don't know what they cost,
but they are available. We have them used, if you need it.
i have a 73 up valve
i bought this 1
it does not look like mine
has the big nut im just lost
inline tube tells me they quit carrying the OE style
im hiding an adjustable one for my swap
Use the third one on the right of the picture at this link:
http://www.inlinetube.com/Prop Valves/BLK245.htm
It's the one for Disc/Drum and it will work with manual (no power booster), I know because it's what I'm using on my Demon with same brake set up.
For use on 1969-74 A-body Mopar with drum or disc brakes.
the blk250 is this the 1 it looks just like the 1 on the car
What Demon 408 said is correct........ it should look like the one all the way to the right, ( lower portion of the valve look's like texas). From my understanding, Mopar had two different Disc/Drum combo valve's, one was made by Kelsey Haye's, can't remember who made the other type, but either should work. I do remember reading on mopart's about these valves, and they do sell rebuild kit's for both. I don't know who was selling them. Have you been having some trouble with your brake system, BEFORE you changed out to the newer style M/C?? Hope this help's.
1 day the brake light goes on changed m/c
bleed all the brakes put in a ajustable push rod
brakes feel bad spongey to much pedal travel
before the car stops
after all this light still on
Yes, it's the BLK250. I don't know why Inline Tube has it in two places (under BLK245 as one of two options) and then by itself under BLK250.
Here's what's listed under BLK245: "For use on 1967-74 A-body Mopar with either disc or drum brakes. If your Mopar had drum brakes you had the valve to the right and maybe the texas shaped rear hold off valve. Some Mopar's had the texas shaped valve and the distribution combine into one valve so your car may only have one valve or the two separate pieces, see BLK250 for the one piece valve."
It's probably has a stuck valve (or valving) in the block, and is keeping the brake light on, or your losing pressure somewhere in the system.
Are you certain you have the adjustable rod deep enough into the piston
pocket? The best way I have found, is to use vernier caliper's, so you can check for depth. It's the only thing I can think of.
i will call them monday and order 1
i will check thanks jj
I wish my wife had an adjustable proportioning valve.....
When did this happen? I ordered one from them only a couple months ago?
month maybe 2 now tech guy said the one i needed was prone to leak so they discontinued sale and were looking to replace with a new vendor
If the valve is stuck and causing it sometimes you can free it by bleeding a wheel at a time while someone is pushing hard on it. The way we did it when I worked in muffler and brake shops was right rear then right front and you could hear it pop free. Did you bench bleed the new master cylinder and is it the same bore? If it is not bench bled it will be spongy.
they still have them in stock
$89.00
$11.23 shipping
#blk250
i will try this thank u
i bought this 1
Eddie that's the old style you usually see on drum brake cars. It will work on a drum/disc car but doesn't have a hold off valve for the drum side so it doesn't work quite as good.
Forgot to mention that the valve isn't really a proportiong valve. It is just a distribution block with a switch valve. The switch valve is a pressure sensing valve that senses when you loose pressure to a wheel from a blown line or cylinder/caliper. When it senses the pressure loss the valve inside is ofrced all the way to one side which turns on the light on your dash. It remains in that position untill a repair is made and you bleed the system. Generally bleeding the entire system is necessary to reset the valve, not just the wheel where the problem was. Even then it can get stuck some times and may need disassembled and cleaned or replaced. Looks like your replacing it so that should solve your issue.
Something you might want to consider is leaving your stock 60 % front 40 % prop valve way better brakes than changing it out. Ive done this on my last 5 conversions ive done. Unbeliavable brakes. My 68 FRANKENDART 360 FI 518 OD has this set up manual disc. The harder you push the farther you want to go through the windshield.
The more I read Inline’s explaination, the more confused I get.
What they call a distribution block (250 on the right), I’ve always called a proportioning valve.
Regardless.
I’ve taken several of the ones on the right apart (250). I can’t really can’t tell how that switch works.
It’s got a flush Philips head on the body. That’s all I can see.
Otherwise, there doesn’t seem to be much about them to go bad.
It is all brass except for a spring and two little washers.
They usually aren’t bad.
There is an O-ring and a cupped seal on a plunger.
If you take the cupped seal out of the body (bore) WATCH OUT.
It will expand and you will play heck getting it back in.
If anyone does have a rebuild parts source, it would be nice to know.
