Dillinger Front Suspension Install
300# hold that baby up...wow that thing is a feather
takes #450 / 10" springs on mine....Hemi, but all aluminum
Featherweight not really 3400lbs so I will see how springs work.... I have a 71 Dart, I know a guy that has aluminum B1 engine in a 70 that runs 300's with same shock even and I believe he is same weight.... I'll know soon enough springs are cheap if I don't like it.
some places will let you swap springs out..within a particular time frame.
good luck.
anyone know what a stock a body k member weighs? have to get this one checked again...
Well the lca's mount up perfect now from my goofy k member and the new custom milled spacers worked out perfect. Can start putting everything together now finally.
well everything else went on nice. only issue I have to take care of now is the moog lower ball joints need milled down some so they sitt flush onto the spindle but other than that the rest of the dillinger parts went on nice with the AFCO DA's coil over. I'll get more pics when I put on strange brakes (which I know already fits nice) and get the engine in...
