unknownsnake
Wasnt sure where to put this question?? Has anyone replaced the seals on the pop out rear windows? I have a dart sport. Any secrets or where should I start?
I had a feeling I had to take the frame apart :/
thanks for the help
Excellent tip! Thanks!!I was able to replace the rubber seal (bought from Steele Rubber) without disassembling the frame. I removed the window and frame from the car and removed the screw that holds the latch to the glass (at rear of window). This allows you to move the glass far enough to remove and replace the rubber seal. But, as stated before, if you need to replace the 'flocked' hinge seal you will need to disassemble the frame and good luck finding the flocked seal. I did not replace the flocked seal.
I found the flocked seal here:
http://www.restorationspecialties.com/Catalog-PDF.html
Part No. CHRY32230 on page 20 of the catalog. Caution - not for the faint of heart...
C
Have you actually installed this part on the popout windows?
Yes, I installed these and they seem to do the job. Don't know what else they might fit, but they were quite long - probably a foot longer than necessary.
C
