68gtxman
I used to reMember
10V should be good at the coil. Maybe the reluctor gap is wrong now or the center button under the distributor cap fell out? Did you take off the rotor and forget to put it back on?
I can't tell what's going on at the ballast resistor, but that white wire connected to the left side doesn't "look good" from here
Not tryin' to make fun of the OP, not at all, but this is a good example of how you can't expect 40 year old wiring to run and run and .....................run...............and............run....................
I will get started testing and tracing wires tonight....I also need to pick up a new timing light.
I will do girls from 18 to 43 but not 65 to 72. Auto shop teacher taught me that rhyme 40 years ago and it stuck. Great way to remember firing order.
