Heater Cover/Plate on Firewall
odie601
Nebraska
What is every one doing for a heater heater delete cover on the firewall? I have seen some sheet-metal over and make it really clean. And others just fab a round plate to cover the opening. Does anyone know what a factory delete plate looks like? If I can find something strange to cover the hole I will do that. lol Just looking at options or ideas I may have over looked. Thanks. :brave:
AndyF makes one. See here.
I got a repro plastic one off Ebay before AR Engr. started making them. The one I got wasn't made well at all, it was rough and porous. I may get the AR one anyway to save myself the trouble of fixing the other one.
You could also make one fairly easily. Its just a round, flat piece of material with 4 holes in it and one flat side.
AR Engineering link does not work. I have there link bookmarked and it doesn't work either. Yes I can have a 6" stainless/plate steel one made. Just curious what every one was doing. :brave:
I made mine from heating duct sheet metal, traced the original ring, cut it out with a tin snips and painted, cone me nothing and looks factory :D
That looks great. How big is your circle. I am guessing around 6" but I have removed the heater unit yet. :usa2:
Thanks! Can't remember but i'm sure it is, I just used the metal retainer ring and traced that, worked slick, also used a new gasket to seal it tight, nuts are inside the firewall...easy to get at cause I pulled the heater box :D
