it is not illegal in all state. I seen plenty go across auctions stating the car was re bodied. The problem I have is the ones that hide that it was re bodied and try to pass it on as original.
From Justice.gov, a FEDERAL Courts website aimed at helping attorneys find YOU guilty of committing certain crimes:
1364
Altering or Removing Motor Vehicle Identification Numbers
Section 511(a) of Title 18 makes it a felony knowingly to remove, obliterate, tamper with, or alter an identification number for a road motor vehicle or a road motor vehicle part. Section 511(b) of Title 18 creates exceptions for certain persons who engage in lawful conduct that may result in removal or alteration of an identification number. The legislative history is abundantly clear that subsection (b) is not intended to create a loophole for the operators of "chop shops."
See H.R.Rep. No. 1087 on H.R. 6257, 98th Congress, 2d Sess. 23-25 (1984).
Section 511(c) of Title 18 contains the definitions for "identification number," "motor vehicle," "motor vehicle demolisher," and "motor vehicle scrap processor." The term "identification number" means a number or symbol that is inscribed or affixed for purposes of identification under chapter 301 and Part C of subtitle VI of Title 49.
Title 49, Chapter 301 authorizes the Secretary of Transportation to promulgate motor vehicle safety standards. Pursuant to this authority, Federal Motor Vehicle Safety Standard No. 115-Vehicle Identification Number (49 C.F.R. §§ 571.115 and 565.1 to 565.5) requires public VIN numbers on road vehicles (passenger cars, multipurpose passenger vehicles, trucks, buses, trailers, and motorcycles). Part C of subtitle VI of Title 49 (49 U.S.C. § 33101
et seq.) authorizes the Secretary of Transportation to promulgate theft prevention (parts marking) standards. The parts marking regulations are set forth in 49 C.F.R. Part 541. The mandatory component identification requirement applies to certain high theft passenger car lines starting with model year 1987. In 1995, the theft prevention (parts marking) standard was expanded to include certain multipurpose passenger vehicles and certain non high theft lines beginning with model year 1997.
and....same site:
1376
Proving Violations of 18 U.S.C. § 2321
Section 2321 of Title 18 is a trafficking offense. The previous discussion relating to proving violations of 18 U.S.C. § 511 should be consulted.
See this
Manual at 1375. In the indictment for 18 U.S.C. § 2321 you may wish to use the false or altered VIN actually on the motor vehicle in order to help specify the motor vehicle which is the subject matter of the charge.
To establish a violation of 18 U.S.C. § 2321 the government must establish that: (1) the defendant acquired or possessed a road motor vehicle or component on which the vehicle identification number (VIN) or component identification number (after the component standard becomes effective) had been
removed, obliterated, tampered with, or altered; (2) the identification number was one required by the United States Department of Transportation; (3) such removal, obliteration, tampering with, or alteration was done unlawfully; (4) the defendant was aware of the unlawful removal, obliteration, tampering with, or alteration; and (5) defendant had an intent to sell or otherwise dispose of the motor vehicle (or component part).
In most cases proof of the defendant's awareness of the stolen nature of the motor vehicle (or component) will satisfy the knowledge requirements. Also, the presence on the defendant's premises of several vehicles or numerous components lacking the proper numbers should help satisfy the knowledge and intent requirements.
By removing a plate and putting it on another vehicle, you are creating two vehicle with altered VIN tags and they will charge you twice with this crime.
If you have a custom-built vehicle, you go get a specially-assigned VIN tag, assigned by state. I've seen them dozens of times.
A re-bodied vehicle is not the same as replacing a VIN on a unibody vehicle.
Georgia specifically, via
http://www.boss302.com/legal.htm:
Georgia:
In Martin v. State, 160 Ga. App. 275, 287 S.E.2d 244 (1981), the court found that a man who rebuilt and sold a vehicle with parts containing altered or removed VINs knowingly concealed or misrepresented the identity of the vehicle under Ga. Code Ann. § 68-9916(a). Since the Motor Vehicle Certificate of Title Act requires that the certificate of title for any vehicle that has been rebuilt, reconditioned, or remanufactured must so state on the face of the title, and the certificate of title that the man obtained for the vehicle did not disclose on its face that the vehicle had been rebuilt, the court found there was enough evidence to conclude that he knew the vehicle contained an altered or removed VIN.
The court in Ramey v. State, 239 Ga. App. 620, 521 S.E.2d 663 (1999), denied a directed verdict of acquittal when the court found enough circumstantial evidence that the car dealer sold the stolen vehicle knowing it had an altered VIN, which is prohibited under Ga. Code Ann. § 40-4-22(a). Because the car's true VIN was damaged and then concealed, and a false VIN plate applied loosely to the door, changes that a person in the business of buying and selling cars should have noticed, and the VIN stamped on the false plate and used by the dealer for the bill of sale did not match the car and could not have been assigned to that year vehicle, the court found sufficient evidence to show the dealer had guilty knowledge of the altered VIN.
From http://www.ecfr.gov/cgi-bin/text-idx?c=ecfr&rgn=div5&view=text&node=49:6.1.2.3.31&idno=49:
§ 565.13 General requirements.
(a) Each vehicle manufactured in one stage shall have a VIN that is assigned by the manufacturer. Each vehicle manufactured in more than one stage shall have a VIN assigned by the incomplete vehicle manufacturer.
Vehicle alterers, as specified in 49 CFR 567.7, shall utilize the VIN assigned by the original manufacturer of the vehicle.
Restated one last time, in case you or anyone else missed it:
The
only time you can legally remove a VIN, is if doing so is required to
repair the vehicle, and then you
must re-affix the original VIN tag in the original location.
If the VIN tag is damaged, you
might be able to get a replacement from the manufacturer, and if so you WILL be required to send in the old one. Period. End of Story. Tell Your Friends: Federal law, nationwide. IF you replace a VIN tag in the course of rebuilding a car, it's gotta be inspected to be up n' up by state highway patrol or equivalent.
State law covers
only one-off vehicles built in that state for assignment of non-federal VIN, by that state law concerning generation of a number associated with that vehicle.
