Thanks Guys for the help, its a 66 Valiant 100. It has heat, but that is the only option on it.
In my 65 Cuda, Both wiper pivots are easy to get at even without pulling the dash gauge panel... I also do not have A/C... Fact is I don't even have a heater...
I did remove my drivers side bucket seat so I could lay on the floor for the left side pivot... and other then that, nuts came right off the pivot studs just fine.
Just my Two Cents... But, remember, my cuda has been an ARIZONA car all it's life, so no corrosion !!!
Since the wiper posts rotate only 180 degrees and torque is always in the same place, all the wear is in one place. If you'll mark the pot metal housings before taking them down you can put them back rotated 180 degrees. If you install the grease fittings, those would go opposite your mark.
This removes approx' 50% of the play. Result is smoother, quieter, wipers.
Factory heater delete? ( posted a pic of mine in another thread asking if anyone had or seen the plate before) Cheers
This is a very good best practice. I never thought about doing that.
Yes... Code: 406 Heater Delete -$71.00
So your saying you had to pay for a heater, but if you didn't want one, you still had to pay $71.00 for the delete plate? Give me a break?
My dad bought a Chevy one time and had to pay them to switch optional wire wheels for standard hubcaps.
On my 65 cuda, from under the dash board, undid the wiper linkage then removed the two bolts holding each pivot... Then made/used a slippery plastic guide to push the seal on over the knurled head...
